Hy, I have a L200JETO YR. 2001 that starts fine ,but when it reaches 2,400 RPMs starts surging like going up and down on the RPMs.I have replaced both of the low pressure pumps,Plugs,Fuel filter,Prime Pumps and hoses, should the High press. pump inside the aluminium canister sound when power is applied ,thanks regards...
Yamaha Model L200JETO Drops RPMs after 2,400 RPMs
yamaha L200jeto
What kind a fuel pressure should I get at idlle and at 3,500RPMs ?Thanks for your help,anything else let me know,regards.
OX66 engines VST pressure should be 30-35 psi
HPDI engines VST pressure should be within 35-52 psi
Fuel Vacumn should be less than 4 psi
ÂÂÂÂÂÂÂÂÂÂÂÂÂ
