motor runs good until it gets warm and then it just quits with no warning. Any and all suggestions would be appreciated.It will start back and run about 100 yards.Been told it could be electric fuel pump. thanks
2005 f90 tlrd
Need to run fuel vacumn and pressure test to see if getting enough gas.
update:
vst has no pressure at all. motor will run and idle for a long period of time. even at a fast idle. when switch is turned on; it sounds like electric pump starts.checked voltage to pump and it measures 12.5 .getting no air or gas out of pressure valve even when pressed with screwdriver.
Need to remove and clean tank and pump, may need new pump.
ÂÂÂÂÂÂÂÂ
