1989 30ELG won't spark/no fuel
  • 1989 30ELG won't spark/no fuel
    When I try and start the motor, I get no spark. Also, there is no gas coming out of the fuel line. It is oil injected; so, maybe there is a problem with the CDI or fuel injector system?
    Not sure what fuel hose you are talking about but need to find out why no gas is getting through and repair it.
    Need to test stop switch, then test igntion components with a peak reading voltmeter to see if voltage output test on each component are within specs.
