hi all, i have a 2006 F250. normally the idle speed is 600 rpm.the engine will start and run at 600 rpm. after the engine is put in gear and run it will not idle down below 800 rpm when put back in netural.if the engine is shut down and restarted it will idle at 600rpm. anyone have any thoughts on this problem. thanks
F250 idle
Unless you have the Yamaha Command Link gauges then will need to be taken to a dealer to have diagnostic run on it.
any help is appreciated. i would like to know the proper way to troubleshoot this probelm. the tech i used i have had no probelms with but he can't seem to put his finger on the probelm so far. he did a YDS scan and bleed down test. engine has 800 hrs and runs fine other than the idle going between 600-800 rpm. if i knew the proper way to go about finding this probelm. it might be helpfull. i can bring it to another tech or try to work thru it with the one i have been using. any suggestions or anyone that has had the same probelm could help. any insight on this probelm would help. the service manual says (trouble code not detected)high engine idle speed(below 1200) cause is air leakage. checking step. check o rings on intake,surge tank and throttle body.
any suggestions on this or where i can find someone to fix it in SE MASS. thanks
Service | Yamaha Outboards
like he said find a shop with a master tech
Did you get a print out of what the YDS showed?
Showing what all the readings were when checked might give info needed
has anyone checked the throttle cable and adjustments?
yes any air leaks can cause high idle.
do you have comand link guages?
typically the laptop only tells me whats not wrong.
vacum leaks can be detected using the laptops map readings.
its actually quite simple if the tech understands manifold absolute pressure.
thanks for the reply. no command link guages.checked the cables first then ran the YDS.i am going back to the tech on monday to keep trying.it is very hard to get someone to work on your boat this time of year so it doesn't make it any easier. i run offshore and use to boat a lot so having this probelm is killing me.any suggestions are appreciated. thanks
could be an air leak could be an inrange sensor failure.
compare the data saved when its idling at 600 RPM then again when its idling fast.
the data save will disply about the last 13 minutes of engine operation in 1 min intravels.
what your looking for is what changed.
