I have a 1998Yamaha 150 vmax carbs, my oil pump went out and It burned up a bearing that chewed up my crank. Now I need a new crank but need the model number to order the crank. my numbers got faded off is their another way of getting them
help me with model#
Look on engine block to see has an round aluminum plug with serial number stamped in it.
That serial number is a 1998 dual prop 150 model, model number D150TLRW
I'm starting to guess its not the same lower unit I have a single prop do you think the crank is the same as the others
ÂÂÂÂÂÂÂÂ
