When cleaning the engine after saltwater use, we use the garden house connector. Water comes out of the cooling water pilot hole as well as the outlet on mid-shaft. The manual says to run the eater 15 minutes with the engine apparently off.
The manual does not address having the engine running at idle with the gas hose removed to purge the carb of gas. Is it OK to do this?
CM
CM
