Looked through old threads which was of some help. As well, checked out the manual at local library.
The problem is oil won't transfer to main tank (was working fine first couple times out this year), other than with emergency switch. Pulled all components and clean them. Pump works fine, lines clear, sensors working.
With engine full tilt up I get all but 1 bar (flashing) on the trim indicator. Manually manipulating lever arm has no effect on the indicator bars.
Still have to check resistance of the trim lever leads as a last resort.
Thanks in advance.
Thanks in advance.
