Low pressure fuel pumps rebuild
  • Low pressure fuel pumps rebuild
    I want to rebuild the two low pressure fuel pumps on my 2001 200HPDI and would like to know if the gaskets and diaphrams (and anything else required) are sold in a kit or only by the separate piece. Is this: 6E5-24410-10-00 FUEL PUMP ASSY the complete pump with all internal parts, ready to bolt on and operate, and are both of my pumps identical?
    Thank you.
    No there are no kits available, once you take pump apart and it needs more than one diaphram probably will be cheaper to replace pump.
    6E5-24410-10-00 is the complete pump, it does not come with gasket between pump and engine block.
