Ok guys so here it is my brother and I bought a 23' well craft last summer with a 1986 etxj 200 hp outboard the guy was forward and told us it run rough and could start it and keep it running if he kept toggling the choke switch but it ran rough and kept coughing and sputtering, we thought bad gas and dirty carbs, got it home and cleaned and rebuilt all carbs set to factory spec fuel air screws, new gas lines, gas, gas filters, and plugs, no help in the situation same problems as well as overheating on muffs in a barrel and on the trailer backed in the water, checked electrical bad stator replaced stator and pulser, reset timing another go throug on the carbs, Also new impella when changing the impella there was what looked like a new one in it appon further inspection found pieces of an old impella in the tube up to the motor as well as in the water jackets pulled all covers and heads acid bath to remove scaling and all chambers cleaned new thermostats an gaskets as well as the rubber grommets were the pickup tube and water pump come together now we have good water flow from the indicator but still overheats in a matter of mins on muffs. Now when I refer to overheating the alarm sounds and we shut down ASAP, with new stator and pulser runs better no more coughing or sputtering but still can't get to run perfict, any advice on setting carbs? Vacumme sync seams to be the response but can find anyone who does that in our area and not sure how that could even be done on these carbs, we have synced the throttle linkage as stated in the service book as well as put new plugs in again first set did not look bad but did it anyway, as far as overheating goes what could it possible be? Completely lost in that aspect, this is the short version of our problems we have had a hard time diagnosing problems because there have been several missing parts and pieces along the way but I am pretty confident all is there now, also compression in all cylinders is 113-115 psi, and I fought to mention the fuel pumps were also rebuilt with new diagrams and gaskets, and all vaccume, oil and fuel lines have been replaced as well
Any advice would be great
