Since about six months ago, whenever the starbd engine is in nuetral(running or not, key switsh on), a intermittent alarm sounds. As soon as the engine is put in gear(fwd or rev) the beeping stops. The system still works and shifts normally so we have just kind of tolerated the 'beep-beep' because it only beeps from the upper station(lower stbd alarm is inop). However, now the port engine is doing the exact same thing (lower port alarm does work and is loud) and needs to be addressed.
Just to reiterate, everything works perfectly normal. Both engines shift normally from both stations. Both engines start in nuetral and do not in gear. I'm reading that it may be due to the shift cables(actuator to engine) may be getting stretched or something. The cables are probably around five years old. Any thoughts?
