I have a used 70-TLRX 1999 I put it in the water for the first time this weekend. it started fine and rev's up fine but when I push the power full, it falls on it's face. it seem's to run fine a 1200 RPM or less. after getting it home and doing some checking #3 cylinder is not firing, compression is 135 same as #1 & 2 cyl. removed spark plug wire on #1 & 2 both had drop in RPM #3 no change. swaped #2 coil with #3 no change. also swaped #2 coil feed wire to #3 still no change. any ideas?
C D I / I think?-
So from your tests you have eliminated, spark plugs, coil and spark leads. There is a possibility of it being the CDI, but I would want to either borrow a known good one or failing that eliminate the other parts of the firing circuit. This is a link to a site that may help you out. Look under support. You will probably have to obtain a multi meter and a DVA adapter.
CDI Electronics: The World's Leading Ignition Spe******ts ::: 1-800-467-3371
ÂÂÂÂ
