Was wondering if someone can point me in the right direction on a problem I seem to be having with my oil level sensor. I have checked other threads on here and can't seem to find what the problem is. The problem is that the oil is not transferring from the remote tank to the engine mounted tank and the gauge (which is a tach with LCD bar readout below) shows the middle bar flashing as if it is not getting signal.
I have tested what I could find in other threads and they are as follows.
The oil will enter tank when bypass is pushed after holding the button for a few seconds.
I have ohmed out the engine mounted oil tank sensor and all checks out ok with it.
I have checked continuity in the blue wire and the black wire from the remote tank to the engine tank and both checked out ok. I haven't checked the other wires from the remote tank as I can't find where they terminate on the engine (or they may not terminate there).
I tried ohming out the remote tank sensor, but am not sure which wires do what on that and can't get a reading with any of the combinations that I tried.
If anyone has any ideas, please let me know and I will work on them next. I am going to go ahead and order the remote tank sensor new and install that this upcoming weekend.
Also, should the oil line from the remote tank to the engine tank have a one way valve / backflow preventer installed on it? It seems as though I have to hold down the bypass switch for quite some time before oil starts showing up at the engine mounted tank. I don't see one on the schematic from yamaha, but may be looking in the wrong place.
Thanks to everyone,
Brad
Thanks to everyone,
Brad
