250 no start and some
  • 250 no start and some
    I have a 91 TXRP 250 yamaha, went to go out today and no start, spins over, also the fuel pump isnt coming on, choke inop, and the t&t remote on the cowl is inop. checked all wiring from ignition to engine, cleaned all grounds, by passed the dead man and nuetral saftey, put a little gas in the cylinder and it fired right up has good spark, just dont have power to the otherelec fuel pump choke TnT Thanks
    Check fuses on motor.
      250 no start
      Fuse is good changed it any way same
        Check compression, check for spark at plugs, check fuel system for water, gas getting to carbs? check all grounds on engine.
          No spark electric fuel pump inop choke inop tilt and trim on cowl inop. The boat ran 55 mph last week
            use a volt meter to see where you have voltage and where you do not, and then back trace to find the problem
