wiring replacement
  • wiring replacement
    i have a 2010 bennington poontoon boat with a four stoke 60 hp. yamaha,
    a squirrel made a nest atop one of the tubes and chewed the wires in two.
    is there a way to repair this with a new wiring harness? one set of wires has 10
    in the bundle the other has four wires.
    You can replace the main 10 pin harness between ignition switch(if switch is mounted in dash) and engine, here are differents lengths available+
    688-8258A-50-00 16FT
    688-8258A-60-00 20FT
    688-8258A-70-00 23FT
    6K1-8258A-40-00 26FT
