How much H.P. is lost from the crank to the prop ? What is the average % diff between the two ? If you dyno a stock 115 V-4 Yamaha at 5500 RPM at the prop how much more HP would a dyno show if it was tested at the crank ? Joe Raimondo
HP rated at prop / HP rated at crank
