Help with Yamaha 225 EXCEL Motor
  • Help with Yamaha 225 EXCEL Motor
    225 Hp Yamaha (1989) Was running great until this past summer.
    The motor had trouble restarting after is had been in use for a while. I know it is not vapor lock, I have changed every filter on the boat. All new spark plugs, and new fuel lines.
    At the end of the season the motor would not start. After a solid day of working on the motor i was able to get it going with a little starter fluid. Again once it gets going it runs fine but at the lower RPM it stalls and has trouble restarting..
    Carbs likely need cleaning....
      Do a compression check as a starting point.......or leak down test
