I have a 2001 Yamaha 4 stroke 80 HP carborated engine. less than 200 hours on it.
Entire engine gone through , new impeller, thermastat , carb kits. Zincs were all good. Heres my question.
Engine runs awesome and a solid stream of water flowing from engine however after engine has been running for awhile the stream of water for the cooling slows to a trickle......is this normal? Engine has not over heated or emergency alarms or shut off have happened as i understand this engine has that protection system on it to protect from over heating. When I bought engine it was run in salt water 1 -2 months every year for a totlat of 5 years and i thought salt deposits were dropping off inside and clogging the outflow discharge line after it warmed up which did happen however it has run long enough and I openend up the outflow line and made it bigger.
Its almost like the engine is acting like it has a thermostat that works like one in your car. Is this the case with this engine and is what Im experiencing normal? I like to see a constant solid stream of water flowing from my engine.
Any advice input and help is greatly appreciated..
