4hp
  • 4hp
    hi just got are 4hp 4stroke yanaha do i mix fuel with oil and is it 50.1 in my tank can any one help
    it a f4amh made 2008 if that help
    Please read what you just wrote "4 stroke motor" the only motor that you mix the oil and fuel is a 2 stroke motor. Please be sure of your motor.
      Only use straight gasoline with no oil added in that 4 stroke motor. Add about an ounce of Stabil to each gallon of gas to help prevent fuel from degrading and causing fuel system problems. Good Luck!
        Pull the dipstick on side of engine to make sure there is oil in engine, use 10W30 motor oil if need to add any.
          cheers
          thank u for u help
