Birddog4
  • Birddog4
    I'm trying to remove the lower casing that houses the exhaust on a 1995 50 hp Yamaha. I've remove the lower unit and all the top bolts but can't get it off.
    What am I missing?
    What am I missing?
    Did you disconnect the shift rod?
      There is a bolt hiding under the trim anode. Take out that black cover and remove the anode then look for a bolt in that area.
      On my motor it is bolts 4 and 9 in this diagram. I think you will find something similiar. 1997 70TLRV Yamaha Outboard LOWER CASING DRIVE 2 Diagram and Parts
        What am I missing?
        So, in other words you are trying to pull the power head?
          Not really...I have removed the lower unit and have taken all the bolts out from the top of the casing but can;t get the middle casing loose.
            Thanks for the reply.. I have the lower unit off with no problem. It's the middle casing that I can't get off. Any thoughts are much appreciated/
              You will need to remove powerhead and motor mounts to get the mid section off the swivel bracket.
