2003 F115 TPS adjustment
  • 2003 F115 TPS adjustment
    I have to turn my TPS clock wise as far as it will go to get .703 with throttle valve opening at 0. It is supposed to be .732 +- .014. is this a sign that my TPS is bad? or is there something I am missing?
    If you are using the correct wires to test output voltage then must be bad TPS.
      I am reading the TPS from my lap top using YDS 1.30
        Must be a bad TPS then.
          thank you very much..
            thank you very much
