I'm planning on replacing the Yamaha filter with a Racor and would like to know if I would I use a 30 GPH or a 60GPH Racor to replace the Yamaha filter?
Racor filter for 07 F225
Good idea. Believe the 60GPH is a 2-micron Racor and it's a direct screw on replacement. You'll also need the bowl, either plastic or aluminum. Can't recall the part number but you can search this forum and find it. Boats.net has them but you need to talk to tech support for ordering. I've been replacing mine every 50-hrs. Need to install a vacuum gauge but can't find one that has a small enough range. I wouldn't consider a 30-GPH.1999 Grady Sailfish SX225 OX66
