Had a bad batch of gas. Went ahead and drained out the fuel tank and replaced and changed all filter's. Drained out and cleaned the carbs and used air to open the hose passages. Engine is still running rough and stalling out. Found out that there are 4 element filter's, Part #67F-14371-01-00 that are in the carb input somewhere and can, and will, clog up with crap. What I need to know is how to I get to these guy's? Do the Carbs have to be removed to access them? The fuel line inputs from behind the carb assembly and cannot be reached to remove them.
2002 Yamaha F100 TLRA Fuel Starvation Problem
