gas in oil
  • gas in oil
    hello,new to the forum.i have a 2005 f115.when i ck my oil the crank case was full and smells like gas. Any ideas?
    You getting at least 5500 rpm with a loaded boat? If not see if you are not overpropped. Long periods of *****ing will also have some motors making oil.
      yes i turn 5800 rpm.but i do alot of *****ing.what about a leaking fuel pump diaphragm or a stuck injector?
        Check that compression is good, check themostats are working properly, check fuel pump diaphram.
          Thanks,how do ck a thermostat on a outboard engine.also best way to ck
          fuel pump.thank you.
