hi all
i run a dual set up of 225 and one wont start.
as decribed here before it is very hard to see spark on yami but i am pretty sure there is none.
tested so far
12 volt to motor dropped to 9 while cranking, added jumper direct to motor nov 11.5 volt during cranking
yellow wire to ymis 12.4 at ing on and 8 volts during cranking before jumper cables now 9.5
all 3 pulsar coils ohm at 320
low speed charge coil 39-40 volt during cranking (red + brown wire)
high speed coil 10 volts
checked ground connections = fine
changed plugs
swobbed Crank pos sensor with other motor
measured 0-0,3 volts on inlet on all ign coils
swobbed remote ign swits and neutral with other motor.
is the low speed coil voltage okay at 40 volts ? i am not able to get any ohm reading but also not on the other motor as well (maybe bad multimeter )
it started when i was out boating and the fuel diaframe cracked i changed it and the boat ran great rest of the day,next morning it wont start and not since....
gentalmen start your brains thank you
bye the way when i turn ignition on the horn sounds like normal and gets silent but sometimes during cranking i get a high speed pulse beep
tested so far
changed plugs
