We have been running the above yammy V4 with an intermittent yearly problem. We can start the motor with enegine choke on, and warm start. We then close the engine choke, and the engine revs freely with the warm start lever fully up. As soon as we try to reduce the warm start to idle the ending stalls.
The engine is powered by an inboard tank, which has been pumped out twice. The engine has been serviced, new plugs, filter and impellor.
Tonight we managed to get the engine started, and once we managed to get it in gear (without stalling the engine revved fine at 5500 rpm and the boat did 45mph). As soon as the revs drop to 3000rpm the engine starts to struggle (and almost misfires). At low revs we can hear an almost hissing noise coming from the engine.
To try and get the engine started we cleaned the idle jets on the top carb, and they were clogged with an oily residue (did not have time to do the lower card).
I am hoping that the bottom bank of carbs need to have the idle jets cleared, as once the engine gets above 3000 rpm it runs fine.
Any tips re: other causes, or how to effectively clean carbs etc etc.
