Yamaha 40 running in safe mode. Shop said oil pump not pumping need to replace. Premixed fuel and checked while running in top carb. Vey little oil at 3000 rpms. Engine was running in safe mode, jumped switch on back to turn off rpm reduction.
What wires do I jump to make engine think it is getting oil?
How do I clean and check precision blend system?
If I can locate problem would like to keep injection system.
I have cleaned carbs and removed and checked theromstat in hot water. Engine does not seem to be overheating, can hold my hand on it and water pump is working fine although I am going to replace impeller.
