Can any one tell me what steel is used for the earth starps ( ground leads).
These are the wires that you will find mounted externally on the motor , and will usually be between the
1) grease nipple on the pivot tube and main mounting
2) between TT unit and bottom anode
3) linking the gearbox casing to the pivot tube(at the grease nipple)
I had a look at them and the lugs(terminals/connectors)and they all look like Stainless Steel.
I was advised that they will not be stainless wires , as the reaction between the alu casings and the stainless steel , will actually accelerate corrosion
Yes i know they are cheap to buy , but yamaha does not carry stock
and you have to wait six weeks , so i would rather just make my own
Can any on please advise
Best regards
Best regards
