oil level lamp wiring
  • oil level lamp wiring
    I have a 1996 S200 txru s/w series II. I have a manual but it does not show the wire colors from control unit to the lamps. If anyone out there has this info i would certainly appreciate it if you would post so i could retrive for my records. THANKS
    The wire colors may not be same at tach, wire harness and on engine, Yamaha sometimes don't match each wire color in harness to what it connects to. Not sure what problem you are trying to solve.
      I have an analog tach without lamps and i am trying to run my wires down from control unit to my gauges. Any help would be greatly appreciated. THANKS!!!!
        The green wire from engine oil tank is green light(full)
        The black/red wire from remote oil tank is yellow light(low oil)
        The green/red wire from engine oil tank is red light(no oil)
          The wires on my motor does not match these colors. My remote tank has a blue, black, brown, and a blk/red. My engine tank has a black, blu/wht, blu/rd blu/grn.
            Engine tank blue/red is no oil warning and blue/green wire is full oil level.
