YAMAHA V4 115 HP 1991 AUTOLUB, couldn't stop the engine...
  • YAMAHA V4 115 HP 1991 AUTOLUB, couldn't stop the engine...
    Hello,
    We 've just changed the sparks on this engine ( YAMAHA BR8HS-10 ), wich is running fine, but since this operation, made by a friend, we lost any way to stop the engine with the emergency button, or the key switch... curious...
    I' ve tested the switchs with a multimeter, they are all fine, nothing was disconnected inside the command, or near the engine...
    What could it be ? Maybe a bad ground return, but how could I test it ?
    Does someone know where the kill signal is routed before the CDI unit and after the CDI.
    Thanks for your help !!
    Thanks a lot.
    Check continuity on white wire in main harness that goes between engine and ignition switch for open circuit.
      Yamaha 115 hp 1991
      Good evening,
      problem solved!
      I have retested the ground return to the CDI, there was an odd-sized cut on the white wire (kill), I put a new wire to the emergency switch,, now everything is allright.
      Thank you so much for your help and good luck to all handymen!
