I cranked her up to take her for a spin...then remembered I had to run home. Returned and it would not start, nor would the fuel tanks show level. My trim tabs and radio, running lights, basically everything else worked.
I recycled the batterys, replaced the battery selector, cleaned all the buss bar connections. Pulled out the detachable connectors under the dash and reinserted them. I was going to attempt to reset the connector plug on the right side under the engine cover, master wire bundle but I could not figure how to un-seat or un-lock the plug. I measured under the dash the wires coming from the engine and have not seen any voltage. I am a certified aircraft mechanic but not an electrician...sure would like to gain some local knowledge from some of the senior heads and others that have local knowledge in this area. Of course I wish to solve this myself for personal reasons.
