Tachometer Manual Question
  • Tachometer Manual Question
    Where can I get a manual for the one in this kit? 6YR-W0035-E2-00
    I don't think there is a separate manual. The instructions for use are in the outboard manual, at least they are for mine.
      You can try here http://www.yamaha-motor.com/outboard...home/home.aspx I think most of the newer four strokes owners manuals have basic tach set up info. You can view the owner manuals online maybe even print. good luck
        Is that the square command link gauge?
        if so, see if this is what you are looking for
