Hey guys. New to the fourm. Need help with engine problem. Z150 started smoking severely. I have 2 cycle oil covering the bottom of the engine coming out the foot. THe primary pump in the tank was still running after the engine shut down. Any info or troubleshooting techniques are greatly appreciated.
z 150 hpdi problems
"The primary pump in the tank was still running after the engine shut down"
Are you speaking of the oil transfer pump in the remote oil tank?
If so, do some searching on the forum on the oil system. There is lots of info on how it works and trouble shooting
motor still not working right !
Yes, the remote pump for the oil was running with the key off , small tank was over full . It has had two oil float switches put on it in the last two weeks. Only thing I can come up with is it has a short in it . It will run fine starting out and after 2 hours or so engine gets bogged with oil .. .... anybody have ideas on what to check ....????
