I recently purchased a 2002 boat with a Yamaha 225 OX66 engine. The gentleman I purchase it from rarely used it and it looks brand new. It ran fine the first couple times I took it out. The last three times I ran it, it started hesitating around 5000RPM. Almost like the fuel is shutting off intermittently. Under 5000RPM it runs perfectly. It would run up to 5600RPM previously without issue. I changed the spark plugs, checked the fuel filters, cleaned the O2 sensor, but it still does this. Do I need to change the O2 sensor? I have read many articles stating that this ended up being the culprit. This engine does not have many hours on it and when I cleaned the sensor it didn't have much residue on it. Any help would be appreciated. I also read that a defective O2 sensor can damage the engine if it's not corrected. Thanks,
2002 OX66 Issue
