I just purchase a 93 115HP two stroke with stiff steering. I've disconnected the steering cable and the engine is still difficult to turn. Movent back and forth if very difficult and sounds like the bushings are dry. I've tried adding grease but it only comes out the bottom bushing. I've tried soaking the upper arm with PB Blaster and moved the motor back and forth with not much improvement. I've tried heating with MAP gas to get the old grease in the upper bushing to move but this has not worked.
Has anyone drilled and installed a second grease zerk at the top of the shaft into the top bushing? If so where? Or does anyone have any other ideas.
thanks,
Mark
thanks,
Mark
