can i change the leg on my motor to a jetleg ???
2003 Yamaha 90 hp outboard
If you have the two stroke with a 20in shaft you will need the Y90 pump from Outboard Jets - Make Every River Longer. You will also need to raise the motor about 5in, an adjustable jackplate works well for this. If you're not in a hurry, keep an eye on ebay or craigslist as the new pump assembly runs around 2k.
