I have a 2003 115 TXRB 2 stroke. I’m experiencing intermittent power loss, it’s almost as if my revs are being restricted. The problem comes and goes… no consistency or pattern.
I only experience the problem as I’m coming to a plane. If I get to a plane without an RPM drop she runs fine for as long as I’m on a plane. I can run for hours with no power loss. She’ll get to 5500 WOT but I typically run her at about 4200-4400.
If I lose power while climbing to a plane, the revs fluctuate between 2800-3700 and makes no difference if I throttle up. The only thing that will fix the issue is if I have someone constantly pump the primer bulb while I’m running. I thought it was an issue with the fuel pump. I replaced it, re-built the carbs and replaced the primer bulb but it made no difference.
Any suggestions?
Any suggestions?
