Hi guys, Sorry if I'm doing this wrong, but new here!
Basically I've got a 1997 225hp saltwater series, and the propshaft is bent, as in you can see the end of it moving up and down when you turn it by hand. I spoke to an outboard mechanic, who said not to worry about it, but surely this will be causing vibration issues, flogging out seals and bearings etc? Not to mention affecting performance?
While working on it today, I tilted the motor down, and oil (yellowy colour) dribbled out of the holes (one on either side) above the top oil fill plug in gearbox. I thought they were water holes?
My questions are, should I be worrying about it? Is the oil leaking out the top a sign that the seals are knackered?
And if I need to get a new prop shaft, is it possible that I can do it myself? (I'm an engineer, and used to be a car mechanic, so have a reasonable idea of whats what) If so, What parts will I need? Prop shaft? new bearings? new seals?
Sorry for the long winded post, just trying to explain myself, and as I'm in New Zealand, would need to order the right parts first time, so the boats not stranded for months waiting for more parts to arrive!
Thanks for any help!
