I have a 25ESD motor. Recently I was fishing and after running about 15 minutes at half speed the motor just about shut down. It would run but was spurttering. Next day, I changed plugs, then I hooked up the water hose and ran the motor at half speed. After about 25 minutes the motor shut down like it has done the day before. Then I noticed that there was no water coming out of the water pump, so I turned it off. I have ordered a water pump kit. What do you think is happening? I, also, cleaned out the fuel filter; no sign of any water.
Motor problem
