2000 yamaha 200 hpdi help
  • 2000 yamaha 200 hpdi help
    I have a 2000 yamaha 200 hpdi on my 23' mako center console....The past two time I took it out it has no power and chokes down like its not gettin enough fuel... I changed the plugs and changed out the feed line filter, but still no luck. I can let it sit for a lil while and crank it and it will run fine for a minute then it just loses power and dies.. I can cruise at 2000rpm and it does fine but try and open it up and nothing...
    Anyone have the same problems or any advice??
    monitor fuel pressures and fix the problem before you smoke a piston
      Cannister filter above vst could be clogged
        2000 Yamaha 200 hpdi help
        Replace the 2 basket filters in the high pressure pump. They aren't in the parts manual but they do exist. I had the same problem about a year ago. I found the basket filters at Napa Auto Parts Part # 2-15001 $1.49 ea. size (6x3x12)
          I had the same problem and the primer bulb would not get stiff. I replaced the LP pumps, they had a large hole in the diaphragm's.( 200 ox). Runs like new. Only has 200 hrs on it. Hope this helps,RV
