Hello,
This is my first post and it will be a long one. I have a 2005 yamaha F50TLHD motor that is having fuel/engine problems. I live in Ca and use only Chevron 92 octane along with 2oz of Marine grade Stabil in my fuel along with a can of Seafoam everytime I fill up. My gas tank is poly and it is 18 gallons. Here is my problem About 2 years ago I replaced all injectors, spark plugs, new VST filter, and low pressure fuel pump and added a Yamaha water fuel separator.
The engine works great when on trailer and water muffs connected. I put the the boat in the water and put the engine idle warmup on for approx 5 minutes to get the engine up to temp. I leave the dock enroute to fish and the motor works fine. The problem occurs after a period of low speed *****ing ( 1.5-2.5 mph) and when I get ready to motor out the motor sputters/surges and wants to die; as if it is starving for fuel. I was told by my mechanic to put the engine in idle and rev the engine idle warm-up to purge the engine before I go WOT.
I have checked to make sure there is no water in the fuel and have checked sparkplugs and all hoses. This motor is an international Yamaha I bought over the internet and it came from Canada. My mechanic has tried everything he can think of. We were goning to test the fuel pressure on the fuel rail but there is no connection port on the rail The only shrader valve that can be seen is located above the VST. I am think that the high pressure pump inside the VST is going out. If anybody has ANY idea what could be occcuring please feel free to PM me. Thanks
