6H0-81960-00-00 RECTIFIER & REGULATOR ASSEMBLY
The book has readings for this assembly, they are either closed (short) or open - well I have a few readings that have resistence, and not completely shorted - not sure if this is correct or not. The books terminolgy is Continuity and Discontinuity - but gives no values for Continuity.
This box receives input from the Lighting Coil - does this effect or could effect cyclinder #2 only.
I can run the engine when disconnecting the two yellow lines from the CDI unit - but then only cylinders 1 and 3 fire - since 2 is con*****ed from the CDI box.
All resistence readings are good - crank, lighting, charge, pulser, coils.
The CDI has been swapped out, but does not correct issue.
