Hope someone can point me in the right direction.
I am having a problem when I go to take off under full throttle, it seems as if the motor is not getting enough fuel and it bogs out. If I feather the throttle and get it up on plane slowly the motor runs fine. When running down the lake at full throttle the motor is also fine
I had it in for a tune up, they changed the water seperator filter in the boat and also a filter in the motor (can't remeber which one), changed out the plugs and the compression across all cylinders is excellent.
This problem has just started this year I though it might have been bad gas, but since the problem started I have run about 3 tanks of fresh gas.
It's on a Skeeter ZX 225. Hopefully someone can help as the dealer is stumped.
