Hello. There is a problem in the oil area. If I leave motor on tilt over night with oil tank on side of motor, oil will run through oil lines into engine.
Also when motor is running, I can't get full power or even half power. Every time I use the throttle, it will splutter and die out but if I idle throttle or just over idle, it will run good at that speed only. Please help.
