Hey guys this is my first post. I just bought a grady with twin HPDI's the stbd motor is having oil transfer issues. I know there have been a million threads on this and I have read all of them but I am stuck and at a loss. I went through the troubleshooting manual, here is the run down. Had the boat out and low oil alarm went off, shut the motor down and refilled the engine oil tank and ran her home. The remote oil tank is full. With the key on I tried the emergency switch and pump did not come on. Yesterday I put power straight to the pump, it kicked on and transfered oil to the engine tank. I have continuity at the remote tank pump, emergency switch, and oil level sensor in the engine tank. Went through the trouble shooting steps today, I grounded the blue wire going to the remote tank pump and it came on and pumped oil. The next step says "Test the PBS control unit black wire for proper connection to ground" I traced the wire and I don't know where it grounds to, looking at the schematic i can see it goes to a ground but I don't know where. The black ground wire runs to a connector on the outboard side of the motor and runs down to ??????
It says if the ground is good replace the PBS control unit. I have no idea where the PBS control unit is on this motor. Can anyone help me out with this issue? I've looked through IPB's and the service manual and cannot find anything about the Precision Blend System (PBS) control module. Thanks in advance for your help guys!!
