F115 2002: sneezes at idle, rattles, like 1 or 2 cylinders missing and sometimes died. TPS is new and 0,733V adjusted. It starts at 800-900rpm but after running 5 mins it comes to 600 or 500rpm and died. Engine starts without error code but with ignition advance: I heard this famous clicking sound (clickety, clatter). When I throttle and run 5 or 10 mins at 4500 rpm, clickety seems to stop, engine runs fine up 5600 rpm and when i come back to neutral, engine dies.
I think it is ECU that gives a bad timing ignition, how I could test it ?
Is it normal to have ATDC 4 deg at iddle and BTDC 15 deg at 3000rpm ?
DIAGS at IDDLE:
Engine Monitor,
,Monitor Item,Result,Unit,
,Engine speed,875,r/min,
,Intake pressure,544.0,HPa,
,Intake pressure,16.10,inHg,
,Atmospheric pressure,1013.5,HPa,
,Atmospheric pressure,30.0,inHg,
,Ignition timing,ATDC 4,deg,
,Battery voltage (12-16),14.80,V,
,Throttle valve opening (0-90),1.6,deg,
,ISC valve opening (0-100),76,%,
,Fuel injection duration,2.29,ms,
,Water temperature (below 90),52.5,°C,
,Water temperature (below 194),126.5,°F,
,Intake temperature (below 70),35.5,°C,
,Intake temperature (below 158),95.9,°F,
,Oil pressure switch,OFF,,
,Engine stop lanyard switch,OFF,,
,Shift position switch,ON,,
,Dual engine system switch,OFF,,
DIAGS at 3000rpm:
Engine Monitor,
,Engine speed,3080,r/min,
,Intake pressure,456.2,HPa,
,Intake pressure,13.50,inHg,
,Ignition timing,BTDC 15,deg,
,Battery voltage (12-16),14.60,V,
,Throttle valve opening (0-90),6.3,deg,
,ISC valve opening (0-100),100,%,
,Fuel injection duration,1.98,ms,
,Water temperature (below 90),48.0,°C,
,Water temperature (below 194),118.4,°F,
THANKS
DIAGS at IDDLE:
Engine Monitor,
DIAGS at 3000rpm:
Engine Monitor,
THANKS
