I have a 2005 50TLR that runs fine for the first twenty minutes. Stop the boat let it sit for a few minutes start it back up and it won't take the throttle. It gets progressivly worse the longer you run it. No buzzer.
Turn it off let it sit for until cool and it will run fine again.
Very low hour motor. New water pump and the thermostat works fine. It's not over heating. I tested the buzzer and it works fine. And the carbs are clean as a whistle.
Pumped the fuel bulb. It was hard and it made no difference. Pushed the choke, again no difference.
I pulled the sensors out of the head and left them cool to ambient temerature, no difference.
I got it running and unhooked the timing arm on the CDI and it helped a little when I moved it manually. It acts like as soon as the CDI gets warm it fails.
Any help would be appreciated. Thanks Mike
