Guys,
I bought a 1994 C75TLRS Yahama , took it out to lake to try it out, was bogging down on wot ,seemed to idle well . Brought it back home , pulled the carbs off & cleaned them, fixed a leak in fuel pump . Went back to lake to try it again ,has the same problem , bogs down at wot .Got home pulled the plugs , all 3 black & wet . Checked the compression , all three cyls have 90 lbs . If the compression is low ,would this have anything to do with the bogging problem ? Or do I need to pull the carbs again & put in carb kits ?
Does anyone have carb kit numbers ,
Thanks ,
Sherman
Thanks ,
Sherman
