I have a 1997 80hp outboard. Replaced the impeller yesterday and the boat does not go into gear. Reading on the forum, the lower unit needs to be in neutral when installed. My question is, can you change gears by rotating the spline on the lower unit by hand or do I need to use plyers. I can't seem to find neutral by rotating by hand. Any help is appreciated.
Impeller installation problem
