Over Heat Alarm- Just installed rebuilt injectors?? HELP
  • Over Heat Alarm- Just installed rebuilt injectors?? HELP
    I just installed my rebuilt injectors and once I put load on the engine and then a few seconds later the overheat alarm goes off??
    It is a 2004 OX66 EFI engine........what gives? I installed everything back properly.......
    Really could use some help here........
      Nevermind, my mechanic said I reved the motor too much with the weak headphones I have.....
        Ok bass you left the "testing on muffs" detail out of the original post. I've never been able to run my motors on muffs. Low water pressure I guess. Use a plastic 55-gal drum. Did she smooth out with the new injectors?
          She def is running smooth right now but here are the results, seems like they really werent the issue.....but the next test in 2 weeks when I run her on the lake.
