I just changed out the low pressure fuel pumps, fuel bulb and VST filter on my Yamaha 150hp OX66 Efi....and I am still having the same symptoms.
In neutral while idling or in forward and no pressure on the foot pedal the engine is giving out as if it isnt getting enough fuel and will sometimes stop running and cuts out.
I tried to self diagnose the issue then spoke with my friend and boat mechanic and said the problem would show its face at higher speeds if one of those parts were faulty.
I did the first two replacements with no luck, then did the VST filter and took the boat out on Saturday morning and it started and idled amazing!! thought I had a new motor but it was 40 degrees that morning and abnormally cold. So I think it was the cold weather and not the change of the VST filter.
I wound up fishing a lake where I didnt even really need to run the motor to get around, I ran it once in the morning time and it went well, but it seems once the motor is warmed up and I start it then the shaking of the motor starts and then once in a blue moon it will completely cut out ONLY at idle or in forward with no load on the engine. I hit a mound of mud/silt with the motor and after that, thats when the same issue came back with the motor this day, not sure if hitting the mound sucked something into something? or it was just because it was the second time and it was mid day and hot and the motor had finally warmed up to show the problem again.
So I am starting to think its the injectors? My friend just texted me we are going to drain the tanks, not sure why and never heard back from him. But I have filled up 15 times in the past month or so and it is consistent.
